Conveyor Systems
Aug. 24, 2006
DTM Window Conveyors are designed for use in a press window for the exit of parts or scrap.
These heavy-duty conveyors are all-steel welded with 3-in.-diameter knurled drive roll and 0.75-in.-diameter keyed shafts with standard two-bolt flange bearings. Two hand-operated hydraulic jacks adjust 18 in. and 15° vertically. Four 3/4-10 tapped holes securely attach the system to the press.
DTM Conveyors, 21721 Tungsten Rd., Cleveland OH 44117, (216) 531-3585, dtmconveyors.com
