A progressive-scan sensor handles SXGA (1,280 × 960) or VGA (640 × 480) images in 24-bit color, even in random trigger shutter. A Camera Link interface digitally outputs images in RGB or YUV mode for integration into vision systems. The 54 × 43 × 59-mm camera weighs 150 gm and features universal C-mount lenses, external trigger, 50-dB signal-to-noise ratio, electronic shutter, AGC, one-push white balance, minimum sensitivity of 30 lx at F1.4, and edge-enhancement capability. It operates on 12 Vdc.
Toshiba Teli America Inc., 33 Hammond, Suite 211, Irvine, CA 92618, (949)770-8354, toshiba-teli.co
Jan. 10, 2025
Jan. 10, 2025
