Thread Sealants
Nov. 9, 2006
Permatex anaerobic thread sealants for metal-pipe fittings work instantly for low-pressure testing, then cure to the burst strength of most systems.
The sealants resist moisture and corrosion and withstand temperatures from -65 to 300°F. They contain a lubricant to prevent galling and simplify assembly/disassembly, and come in a range of grades and strengths.
Devcon, 30 Endicott St., Danvers, MA 01923, (800) 933-8266, devcon.com/84
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
