Features include die-cast aluminum housing with stainless-steel locking system, multilayered surface sealing, and laser-etched identification marking. These housings are suitable for corrosive environments and industrial applications and come in IP65 and the newly rated IP69k protection class ratings. They fulfill the NEMA-250-1991, Type-4X standard. With integrated insulation strips, all housings are designed for high-voltage applications. The line comes in pole numbers ranging from 3 to 216 and ratings up to 1 kV and 100 A, with and without a ground connection. The ground connection design meets IEC 603 64-5-54 and DIN VDE 0100-540 specifications.
Weidmuller, 821 Southlake Blvd., Richmond, VA 23236, (804) 794-2877, weidmuller.com
Safety Products Overview
Dec. 20, 2024
