New Product: Incremental rotary encoder
May 8, 2008
The CH25 comes with a 2.5-in.-square flange, 0.375-in.-diameter shaft, an M12 connector, and ships with a push-pull driver and quadrature signal format.
The encoder accepts a wide input voltage from 5 to 30 Vdc and is available in resolutions from 100 to 5,000 ppt. The unit is constructed with a powder-coated aluminum enclosure rated to IP67. An additional shielded 6-ft cord set is also available as needed.
Celesco Transducer Products Inc., 20630 Plummer St., Chatsworth, CA 91311, (800) 423-5483, celesco.com
