Auto-Blade Fuse Holder
Sept. 27, 2007
The PC auto-blade fuse holder accepts standard and low-profile ”mini-size fuses” and holds them in place.
To ensure secure positioning during wave soldering, the holder is thru-hole mountable and has fully insulated clips to protect fuses and reduce assembly time. The clip insulators are made of UL 94 V-O nylon and the contacts are 0.016 tin-nickel-plated brass to withstand shock and vibration. The clips voltage rating is 500 Vac and 20-A current.
Keystone Electronics Corp., 31-07 20th Rd., Astoria, NY 11105, (800) 221-5510, keyelco.com
