Remote Head Camera
Oct. 26, 2006
The CS5111L analog color composite camera system is comprised of a compact 29-mm remote head that connects to a separate control unit via cable which can be up to 7-m long.
The half-inch CCD sensor (380k pixels) captures fastmoving objects at a horizontal resolution of 470-lines for high-density color images with reduced noise. Typical applications are color-based machine vision, robotics, factory automation and quality control. PAL and NTSC versions are available. Camera ELC (Electronic Lighting Control) and AGC (Automatic Gain Control) both function at up to 1/100,000 sec. An Auto White Balance function detects color temperature variation of subjects continuously and maintains levels to eliminate white balance adjustment. A power supply is built in. The camera uses a standard C-mount lens and has VBS and Y/C interfaces.
Toshiba Teli America Inc., 33 Hammond, Irvine, CA 92618, (949) 770-TELI, toshiba-teli.com
