Stopper Cylinders
June 7, 2006
Stopper Cylinders feature adjustable roller direction.
feature adjustable roller direction. The units come in 32, 40, and 50-mm bores and seven rodend styles to meet various application requirements. Magnetic pistons allow magnetic sensors to be mounted on cylinder surfaces when input signals are required for controllers. Available styles include double-acting with built-in fail-safe extended rod or single-acting with spring-extended rod cylinder.
Fabco-Air Inc., 3716 N.E. 49th Ave., Gainesville, FL 32609, (352) 373-3578, fabco-air.com
