Insulated Tap Connector
Oct. 12, 2006
The Unitap Insulated Multiple Tap Connector line now includes a mount version, which is outfitted with two isolated mounting holes located at both ends of the connectors.
This allows for direct mounting to trough, gutter, or any wire way. The preinsulated aluminum multiple-tap connectors are for line splice, reducer, and tap applications, and are rated for copper and aluminum applications. A clear Plasitol covering eliminates the need for taping during installation and allows for easy inspection of the connectors. All Unitap products are prefilled with an oxide inhibitor and are contaminant-free due to solid end caps.
FCI, 47 East Industrial Park Dr., Manchester, NH 03109, (800) 346-4175, fciconnect.com
