Product Spotlight: Microsolenoid Driver
March 20, 2008
The D5400 microsolenoid driver (MSD) reduces heat buildup in solenoid-valve operators.
The MSD induces faster pull-in with a high input voltage and then automatically reduces voltage during hold-in. The connector can replace low-voltage power supplies, letting 120 Vac operate a 24-Vdc solenoid valve. The driver lets coils energize for an extended period of time without burnout. Fixed and adjustable versions with standard LED indicator lights and a 9-ft cable are available.
Canfield Connector
8510 Foxwood Court
Youngstown, OH 44514
(330) 758-8299
canfieldconnector.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
