The Size-23 AS66A develops 170 oz-in. of torque while the AS69A holds 280 oz-in. of torque. The Size-34 AS98A develops 280 oz-in. while the AS911A holds 560 oz-in. A protective earth-ground terminal is installed on the metal connector to achieve conformance to ISO-12100 requirements for earth grounding.
Oriental Motor, 2570 W. 237th St., Torrance, CA 90505, (800) 418-7903, orientalmotor.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
