The ICM8 has RS-232 and RS-485 serial ports and a 10 Base-T/100 Ethernet port instead of proprietary COMMS cards. The module allows monitoring multiple disparate devices, and performs conversions of numerous protocols simultaneously by way of built-in drivers. This allows easy data mapping to PLCs, PCs, and Scada systems. The module is programmed using Windows-compatible free software, which can be downloaded from redlion.net.
Red Lion Controls Inc., 20 Willow Springs Circle, York, PA 17402, (717) 767-6511, redlion.net
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
