Adhesive For Plastics
July 13, 2006
ReAct 784 adhesive is for bonding plastic to a wide-variety of substrates including steel, aluminum, phenolic, PVC, ABS, polycarbonate, and glass.
The adhesive resists moisture, temperatures up to 275°F, and chemicals including motor oil, gasoline, and water-glycol. Shear strength ranges from 400 to more than 4,800 psi. The operator applies the activator to one bonding surface and ReAct 784 to the opposite surface. This eliminates mixing and curing.
Hernon Mfg. Inc., 121 Tech Dr., Sanford, FL 3277, (800) 527-0004, hernonmfg.com
Aug. 22, 2025
Aug. 22, 2025
Aug. 21, 2025
