When seated, a preassembled drive pin secures Push-Lok standoffs to the chassis. The fastener portion has a minimum protrusion but sits flush with a shallow dimple in the chassis. Push-Lok latches are flexible and secure enough to allow for easy assembly of daughter boards without using torque-driven screws. The standoffs are made of UL94V2 Type-66 nylon but UL94V0 versions can be special ordered.
Device Technologies Inc.,
3 Brigham St., Marlborough, MA 01752,
(800) 669-9682,
devicetec.com
Dec. 23, 2024
Dec. 23, 2024
