The Eclipse line of servomotor brakes has been expanded to eight size groups fitting more than 250 servomotors from 15 manufacturers. The high-capacity, spring-engaged brakes offer positive stopping torque with enough holding force to stall a servomotor, which improves operating safety and prevents premature brake burnout. The flange-mounted Eclipse servomotor brakes will fit externally, mounting directly between the gearbox and servomotor. All models, including NEMA models, come in frame sizes from 2 to 11 in.
Nexen Group Inc., 560 Oak Grove Pkwy., Vadnais Heights, MN 55127, (800) 843-7445. Hall 26; Stand E34
Safety Products Overview
Dec. 20, 2024
