The connectors offer customized assembly, latching, and removing forces, conductive paths when necessary, small to large glands, high manufacturing tolerances, and minimal assembly. Inner-spring diameters range from 0.020 to 70 in. The connectors can be reassembled by replacing the destroyed spring.
Bal Seal Engineering, 19650 Pauling, Lake Forest, CA 92610, (800) 366-1006, balseal.com
Aug. 29, 2024
Aug. 28, 2024
