Temperature/Process Controllers
April 27, 2006
The single and dual-display CN9-SW Series temperature/process autotune controllers feature a low-cost serial-communicating system with Windows software.
The CN9300, CN9500, and CN9600 Series bridges the gap between stand-alone systems and full Scada fieldbus-control networks by remotely supervising up to 32 instruments using the Modbus protocol. The units display in C, F, bar, psi, pH, rH, and set (Universal unit). The controllers feature a four-digit display, five alarm configurations, single ramp and soak, PID heat-cool control, NEMA-4 (IP66) faceplate, sleeve mounting, and security lockouts.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660, omega.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
