Compact Slide For Light Loads
Sept. 16, 2004
The MM Slide linear-slide system is said to be, compact, highly accurate, and designed for light-load, limited-envelope applications.
It is made of rigid, lightweight aluminum, and arrives factory assembled for quick and easy mounting. The system includes a mounting carriage, four linear bearings, two precision-hardened and ground Class-L shafts, two integrated end support bearing blocks, a leadscrew assembly, and a motor mount. They are available with high helix leadscrews for high-speed applications as well as ball screws for fine, incremental positioning. Adaptable motor mounts fit NEMA-23 frame motors.
Nook Industries Inc.,
4950 E. 49 St., Cleveland, OH 44125,
(216) 271-7900, www.nookindustries.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
