Plug-In Pneumatic Valves
April 26, 2007
Series CA44 valves are two-station valve manifolds for AS-i serial-link (bus) applications and comply with AS-I specification V2.11 Rev.
1. The manifolds come with or without digital inputs and auxiliary power. Valve stations are four-way, two-position, or dual three-way, two-position, or a blanking plate. Valve flows are 0.2 Cv (200 lpm) with pressure of 29 to 116 psi. Voltage is 24 Vdc with a protection rating of IP67 (NEMA-6). The valves come with push-in fittings for 4 or 6-mm plastic tubing or M7 threaded ports.
Bosch Rexroth Corp.,
5150 Prairie Stone Pkwy., Hoffman Estates, IL 60192,
(800) 739-7684,
www.boschrexroth-us.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
