Ultrasonic Flowmeter
Nov. 9, 2006
The FDT100 Series flowmeter uses transit-time ultrasonic technology — two flow sensors alternately transmit and receive a signal and "time of flight" measures flow rate.
The FDT100 Series flowmeter uses transit-time ultrasonic technology — two flow sensors alternately transmit and receive a signal and "time of flight" measures flow rate. The battery-powered flowmeters have no moving parts, minimal pressure loss, and filtration is unnecessary. Long-term stability and a wide measurement range facilitate consumption and leakage monitoring. The meters are available in 150-lb ANSI and DIN styles with a choice of integral or remote electronics that display flow rate or total at the push of a button.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660, omega.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
