Bearings Products: Metal-Polymer Bearing Retainer
July 10, 2008
Composite metal-polymer bearing retainers made from silver-coated polyamide-imide feature precision machining to keep tolerances on cage diameter, ball-pocket location, and piloting-land interface under 0.002 in.
The retainer withstands repeated autoclave cycles and speeds up to 500,000 rpm.
The silver layer is slightly porous to hold more lubricant while the silver itself provides a self-lubricating wear layer and an extra layer of protection against microbial infection. The metal and polymer layers resist reaction with moisture or harsh chemicals.
New Hampshire Ball Bearings Inc.
Precision Div., 9700 Independence Ave.
Chatsworth, CA 91311
(818) 993-4100
nhbb.com
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
