The Pump Station Series of enclosures are designed for use where extra protection from extreme temperatures and UV exposure is required.
The Pump Station Series of enclosures are designed for use where extra protection from extreme temperatures and UV exposure is required. The 14-gauge, Type-304 stainless-steel enclosures feature continuously welded and ground smooth seams; removable hidden hinges that are shielded by door edges; stainless-steel quarterturn latches with flush slotted insert; seamless foam-in-place, one-piece gasket that provides an oil, water, and dusttight seal against contaminants (polyurethane foam (–10 to 75°C) with acrylic tape (–40 to 93°C); installed gasket retainers; installed channels for variable placement of optional internal swing panel; bonding provision on door and ground stud on body; panel studs fit optional NEMA-size panels; mounting holes in back of body for direct mounting; and furnished hardware kit, consisting of panel-mounting nuts, grounding hardware, and sealing washers for wall-mounting holes.
AD Products Co., 4799 W. 150th St., Cleveland, OH 44135, (800) 325-4935, adproductsco.com
