Plastic Bearings
Sept. 14, 2006
Iglide H370 plastic plain bearings are designed for wet environments and high-temperature applications.
The bearings are not affected by moisture, dirt, and dust, are UV and corrosion resistant, and require no lubrication. The bearings have a moisture-absorption rating of 0.0% and, in continuous motion, operate in temperatures ranging from 40 to 392°F.
igus Inc., Box 14349, East Providence, RI 02914, (401) 438-2200, igus.com
