Six models each cover 12 and 90-Vdc inputs. The motors come with gear ratios from 32:1 to 430:1 and fixed output speeds from 6 to 93 rpm. Output torque ranges from 13 to 50 lb-in. All motors are 1/30-hp permanent-magnet dc with replaceable brushes, grease lubrication, and all-position face mounting with a 50-lb overhung load rating.
Bison Gear & Engineering Corp.
3850 Ohio Ave.
St. Charles, IL 60174
(630) 443-5797
bisongear.com
