Fieldbus Cable
Dec. 14, 2006
DataCELL Foundation fieldbus cable targets rugged plant environments that use networked automation and control.
The cable is rated for instrument tray cable/power-limited tray cable (ITC/PLTC) exposed-run (ER) applications. This lets users eliminate the conduit when the cable is installed in accordance with recent National Electrical Code amendments. The cable comes in 18 awg with a foil or braided shield, and with or without ground wire. The cable's PVC jacket resists oil, sunlight, and water, and is available in standard and custom colors and versions.
Northwire Inc., 110 Prospect Way, Osceola, WI 54020, (715) 294-2121, northwire.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
