The connectors can be used for power and signals to factory-automation equipment in the material-handling, automotive, conveyor and automatedequipment industries. Available configurations include 6, 7, or 8-pin connections for the B size and 9, 10, or 12-pin configurations for the C size. Pairing the 6-pin minifast with 16-awg cable (18 awg also available) offers 9 A of current-carrying capability and the 12-pin version with 6 A. All connectors are rated for 600 V. The extended coupling nut design, in either nickel-plated brass or 316 stainless steel, provides pull strengths over 200 lb. The minifast line is rated to NEMA-1, 3, 4, 6P, and IEC IP68.
Turck Inc.,
3000 Campus Dr., Minneapolis, MN 55441,
(800) 544-7769, www.turck.com
Jan. 10, 2025
Jan. 10, 2025
