Glow-in-the-Dark Polycarbonate Sheets
March 17, 2005
Glow-inthedark sheets meet or exceed common photoluminescent-safety and egress standards.
The sheets are available in roll stock or can be cut to length. They include a rigid polycarbonate sheet with white backing and a flexible egress tape. They come with a clear topcoat that protects the substrate from abrasions and resists water, oil, acid, and alkaline materials. The sheets can be printed on using water or solvent-based inks and flexography, offset lithography, screen-printing, or UV-curable ink printing. They can also be laser marked with no pretreatment.
RTP Co.,
Box 5439,
580 E. Front St.,
Winona, MN 55987,
(507) 454-6900,
rtpcompany.com
