Cylinder Adhesive System
May 10, 2007
Nine high-performance Scotch-Weld adhesives come in portable, pressurized cylinders.
With the cylinders and low-maintenance spray gun, there's no time-consuming equipment setup or cleanup, and no expensive equipment or maintenance of spray equipment and compressors. The adjustable-tip spray gun offers multiple spray patterns with a choice of drying speed, bonding strength, and spray widths (from 1 to 12 in.). The adhesives bond high-pressure laminates, foam to foam, carpet to fiberglass, and rubber to metal, to name a few.
3M,
3M Center, Building 220-5E, Source Code 5128, St. Paul, MN 55144,
(800) 567-1639,
3M.com/adhesives
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
