Intensifier Pump
April 13, 2006
The new iP60-50 intensifier pump is rated for 60,000 psi.
The 50-hp unit features numerous design enhancements over previous versions, including a noncontact wet electronic stroke sensor that improves performance and reliability; a simplified piston/plunger design that requires only one tool for maintenance; a redesigned intensifier that assembles with standard tools; and an improved check tube featuring fewer parts than previous models. Featuring an extended-life hydraulic system, the pump provides easy access for service and maintenance. It requires few tools to maintain and can typically be serviced in-house, reducing downtime and increasing productivity.
Jet Edge Inc.,12070 43rd St. NE, St. Michael, MN 55376, (800) 538-3343, jetedge.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
