The motorized stage contains an optical encoder and a piezoelectric Squiggle motor. It supports vertical loads up to 0.5 kg with negligible heating. The motor uses ultrasonic vibrations of a threaded nut to rotate a mating screw, creating linear motion with 2-nm resolution, high stiffness, and little noise.
New Scale Technologies Inc., 10 East Main St., Suite 301, Victor, NY 14564, (585) 924-4450, newscaletech.com
Dec. 23, 2024
Dec. 23, 2024
