The RC80 keeps the tube stationary with two 6-in. jaw chucks, and the tools rotate. This results in faster, more accurate cuts, and quieter operation, according to the manufacturer. The RC80 also offers ID radius machining for both ends. Maximum wall thickness is 1.5 in. Up to three lengths can be programmed for a single tube, allowing short run and best advantage processing. Changeover to another diameter takes less than a minute.
Hautau Tube Cutoff Systems LLC,
11199 State Rte. 101, Brookville, IN 47012,
(765) 647-1600, hautau.com
Dec. 23, 2024
Dec. 23, 2024
