Condensate Pump
Jan. 11, 2007
The Pivotrol PTF4 high-capacity condensate pump is capable of pumping 40,000 lb/hr in rapid-cycling process environments and at elevated pressures and temperatures.
The unit's pressure-balancing body ensures the pump's dual Pivotrol pumping mechanisms share loads equally. Vent-assist valves release pressure in the pump body during the exhaust stroke for faster filling and overall cycling. Two-thirds the size of units it replaces, the PTF4 has 4-in. inlet and outlet check valves.
Spirax Sarco Inc., 1150 Northpoint Blvd., Blythewood, SC 29016, (803) 714-2000, spiraxsarco.com/us
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
