Linear Rotary Bearings
May 5, 2005
Solid linear rotary bearings, designed to thrive and survive in the presence of contaminants, are among thousands of precision electromechanical components in the Ultimate Nordex Design Guide 2004.
Design features include heavy-walled aluminum body for size stability under shock loads and severe loading conditions; vibration-absorbing Frelon liner (a type of Teflon), concentric with ground OD within 0.001 T.I.R.; maintenance-free, self-lubricating, and made to carry greater loads (often 8 to 10 times greater) than antifriction bearings; suitable in oils or water soluble cutting fluids (will not rust); and a temperature range from 400 to 500°F.
Nordex Inc.
426 Federal Rd.
Brookfield, CT 06804
(800) 243-0986
nordex.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
