Rotary Encoder Targets Resolvers
June 16, 2005
Inductive rotary encoders target applications in drive technology, robotics, and general automation previously employing resolvers.
The ECI 1116 is an absolute single-turn encoder with a 16-bit resolution while the ECI 1128 is a multiturn absolute encoder with 28-bit resolution. Both encoders are 38 mm in diameter and less than 28-mm long.
Heidenhain Corp.,
333 E. State Pkwy., Schaumburg, IL 60173,
(847) 490-1191,
heidenhain.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
