Topas 8007F-400 can be used in discrete or COC-rich layers for multilayer films. In blown films, it can work in applications such as pouches, flow-pack, lidding, and twist wrap. The new grade is a clear cycloolefin copolymer that adheres to polyolefins, especially linear low-density polyethylene. It can be metallized and colored easily, and has an inherent moisture barrier that can extend product shelf life. It has a modulus of 2,500 MPa and a glass transition temperature of 80°C.
Ticona Technical Polymers., 8040 Dixie Highway, Florence, KY 41042, (800) 833-4882, ticona.com
Dec. 23, 2024
Dec. 23, 2024
