These cylinders mount into the same space and bolt patterns, provide long service life, and reduce both maintenance and downtime in stretch blow-mold applications. Bodies are 100% machined high-strength aluminum. Standard heavy-duty internal urethane shock pads absorb impact energy and eliminate metal-to-metal contact. FDA-approved lubrication for use in food-packaging applications comes standard. Optional manifold and valve combination is available.
PHD Inc., Box 9070, Ft. Wayne, IN 46899, (800) 624-8511, phdinc.com
Safety Products Overview
Dec. 20, 2024
