Pluggable Terminal Blocks
Oct. 26, 2006
The ASIUK3MVSTB508 pluggable terminal block has a current rating to 20 A at 300 V and a wiring capacity of 26 to 12 awg.
It mounts on a DIN rail, but unlike conventional blocks, there is a pin header on one side on 5.08-mm spacing that accepts the plug-in block. The unit's vertical connector entry provides for a complete circuit from 2 to 20 positions to be mated and unmated in one action. Both the plug and terminal block are polarized so mating is only in one direction.
Automation Systems Interconnect Inc., Box 1230, Carlisle, PA 17013, (717) 249-5581, asi-ez.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
