New Product: Pressure regulator
Nov. 8, 2007
The PR10 motorized pressure regulator is designed to regulate hydraulic-circuit pressure by either reducing incoming system pressure or relieving induced pressure by the load.
Remote adjustment is through a 12 or 24-Vdc motor with a doublepole, double-throw toggle switch or closed-loop system using remote pot or microprocessor controls. Operating speeds are from 1 to 48 sec through full adjustment range. The regulator’s maximum inlet pressure is 5,000 psi and its regulated pressure ranges are 150 to 800 psi, 150 to 1,200 psi, and 150 to 1,600 psi.
Source Fluid Power, 331 Lake Hazeltine Dr., Chaska, MN 55318, (952) 368-3866, sourcefp.com
