Cable-Entry System
Aug. 24, 2006
The KDP cable-entry system has a wide range of cable-clamping ranges and number of entry points.
Three choices of housings are available: stainless steel, aluminum, or plastic. The system provides a quick and easy method of bringing numerous cables into an enclosure. Once the cables are pushed through the multilayer membrane, it seals the entry to provide a level of strain relief.
Murrplastik Systems Inc., 2367 North Penn Rd., Suite 200, Hatfield, PA 19440, (215) 822-7625, murrplastik.com
