Laser And AC Adapter
The 150P Series laser modules with ac power adapters let users plug directly to ac power supplies and get 6 Vdc for the laser.
Sept. 15, 2005
The 635 and 650-nm versions of the laser modules have outputs of 3, 5, and 7 mW. The lasers feature automatic power control with soft-start protection, as well as three-element glass collimating-lens with AR coating. Operating voltages range from 4.5 to 9 Vdc, but 5 V is the recommended rate within a temperature range from 10 to 4°C. Housing is of a durable anodized aluminum. A green LED in the rear of the unit confirms laser emissions.
BEA Lasers, 2330 Brickvale Dr., Elk Grove Village, IL 60007, (800 ) 783-2321, www.bealasers.com
