Foam Tape Could Replace Welds or Screws
Feb. 8, 2007
Industrial-strength pres-mount tape adheres instantly, providing gap filling, and uniform stress distribution.
The foam also cushions joints against shock while dampening sound and vibration. The double-sided foam tape is offered in urethane, vinyl, and neoprene/EPDM/SBR foam to match mounting and fastening requirements. It also comes in a range of thickness, density, color, and width or can be custom die-cut.
Pres-On, 39 Factory Rd., Addison, IL 60601, (800) 323-7467, pres-on.com
