Industrial Network Cordsets
Jan. 25, 2007
Armored M12 eurofast cordsets protect against abrasion, cuts, water, oil, and impact in automotive, stamping plants, and welding environments.
Armored M12 eurofast cordsets protect against abrasion, cuts, water, oil, and impact in automotive, stamping plants, and welding environments. These cordsets meet open-wiring specifications for use in place of conduit, thereby reducing the labor, wire pulling, cutting, bending, and moisture problems associated with conduit. PVC-jacketed cable with interlocking aluminum armor is ITC/PLTC (instrumentation tray cable) rated. The armor connection to the coupling nut facilitates the grounding of the connection. Cable connectors provide IEC IP68 protection, and are rated for 250 Vac/Vdc and 4 A. The line provides three, four, and five-wire options, with 18 and 22 awg.
Turck Inc.,
3000 Campus Dr.,
Plymouth, MN 55441,
(800) 544-7769,
turck.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
