By measuring differential pressure across the pressure ports, and referring to the matching performance curve, airflow can be precisely determined.
Ten sizes are available, from 4 to 32 in., with capacities to 20,000 cfm. Iris dampers are made from galvanized steel. The dampers are fitted with a neoprene gasket for airtight mounting and come in stainless-steel and motorized versions.
Continental Fan Mfg. Inc.
203 Eggert Rd.
Buffalo, NY 14215
(800) 779-4021
continentalfan.com
Jan. 10, 2025
Jan. 10, 2025
