Splicing Connector
Oct. 7, 2004
The 222 Series compact splicing connector is a cost-effective alternative to traditional twist or crimp-style connectors.
The connector offers more flexibility in terminating and reterminating a wide range of wire sizes and types. Using Cage Clamp spring-pressure technology, the connectors provide reliable, vibrationproof, corrosion and temperature-cycling resistant, and maintenance-free wire connections. The connectors integrated orange lever actuator allows for fast and easy wiring with no tools while ensuring a proper connection. An integrated test point permits convenient testing and troubleshooting of the circuit. The 222 Series is UL listed for 600 V/20 A and terminates wire sizes 28 to 12 awg, solid and stranded.
Wago Corp., N120 W19129 Freistadt Rd., Germantown, WI 53022, (800) 346-7245, wago.com
