The pump’s fully molded “wobble” stator increases the compression fit during operation between rotor and stator for improved performance. The self-priming units have nonpulsating, low-shear flow which remains steady even under wide variations in suction head. Additional features include 5-gpm flow rates, pressures to 40 psi, dual, heavy-duty fully sealed and lubricated ball bearings. Mechanical seals are standard on all units.
Moyno Inc., Box 960, Springfield, OH 45501, (877) 486-6966, moyno.com
Jan. 10, 2025
Jan. 10, 2025
