Ultrasubminiature Bicolor Switch
Jan. 12, 2006
At only 2-mm height, the NL Series of subminiature switches has two independent LEDs in any combination of red, green, yellow, or blue.
The switches feature an electrical rating of 50 mA at 24 Vdc with a typical life of 30,000 cycles. Actuator travel is 0.5 ±0.2 mm with solid-detent tactile feedback of 160 gm. Contact resistance is <50 m with insulation resistance >100 M at a dielectric strength of 100 Vrms. All materials are RoHS compliant.
CIT Relay & Switch, 7003 Magda Dr., Maple Grove, MN 55369, (763) 535-2339, citrelay.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
