The ability to connect multiple sensors to one or two analog paths helps keep down overall system cost. Four front panel LEMO connectors can be configured as inputs or outputs. The module lets up to four external instruments be switched into a path via the LEMO connectors. The P580 also controls switching sequences via plug-and-play drivers or scanner memory.
Kinetic Systems Co. LLC,
1 Rue Provost, Lachine, QC H8S 4H2, Canada,
(800) 567-GAGE, www.gage-applied.com
Safety Products Overview
Dec. 20, 2024
