The units come in three sizes ranging from 178 199 mm to 233 264 mm. For each size, a low and high-profile base is available that can be combined with four different lids an open-front frame, a membrane ready, a hinged membrane ready, and an open-front frame with terminal-compartment cover. Bocard features a variable terminal compartment that can be kept separate from the electronics compartment using accessorydivider panels.
Ingress protection of enclosures with the clear, hinged or membrane-ready lids is IP65; for all others, IP40.
Rose+Bopla Enclosures, 7330 Executive Way, Frederick, MD 21704, (301) 696-9800, www.rose-bopla.com
Dec. 23, 2024
Dec. 23, 2024
