Pressure Transducer
Dec. 14, 2006
The Compact 3100 Series pressure transducer uses a highly accurate thin-film technology and custom-designed ASIC to give an accuracy of 0.25% full scale, long-term stability of 0.1%/yr, and thermal stability accurate to within 1.0%/100°F over a temperature range of –40 to 250°F.
The Compact 3100 Series pressure transducer uses a highly accurate thin-film technology and custom-designed ASIC to give an accuracy of 0.25% full scale, long-term stability of 0.1%/yr, and thermal stability accurate to within 1.0%/100°F over a temperature range of –40 to 250°F. The device comes in pressure ranges from 100 to 30,000 psi; outputs of 0 to 5, 1 to 5, 0.5 to 4.5, 1 to 6, 0 to 10 Vdc, 4 to 20-mA, and 0.5 to 4.5-V ratiometric; pressure fittings NPT, UNF, BSP, and metric; and electrical connectors M12, Packard, Deutsch, and DIN43650C.
Setra Systems Inc., 159 Swanson Rd., Boxborough, MA 01719, (800) 257-3872, www.setra.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
