Compact Touch Panels
Nov. 9, 2006
C-more Micro-Graphic panels are billed as touch panels with a text panel price. The panels are available in touch-screen and nontouch-screen models.
The 3.1-in. LCD monochrome screen offers a resolution of 128 X 64 pixels. With 768-kbyte memory, the panels support up to 999 screens, limited only by project memory usage. Projects can include bitmap pushbuttons, increment/decrement pushbuttons, and even a pop-up numeric keypad on the screen. The display panel supports eight lines by 21 characters of dynamic text. Built-in LED backlight has five user-definable colors. An alarm function allows control of backlight color flash, function key LED flash, beep activation, and custom banner alarm displays. Panel configuration software allows the use of bitmap graphics to display images of pushbuttons, switches, and indicators. Panels are UL, cUL, and CE approved, RoHS certified, and are NEMA-4 and 4X indoor rated.
AutomationDirect, 3505 Hutchinson Rd., Cumming, GA 30040, (800) 633-0405, C-moreMicro.com
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
